-   -   Piston Rings (https://www.racingjunk.com/forums/showthread.php?t=21998)
hammertime 10-07-2008 07:19 PM
Piston Rings
What brand rings would you run in a 582 BBC with a vac pump on alky. Also run low tensions or no ?
zipper06 10-07-2008 07:29 PM
Total seal sells a blower/nitrous ring that's pretty good and can stand up to nitrous. But they are about $250.00
altailites 10-07-2008 08:01 PM
Re: Piston Rings
If its n/a I would run the speedpro pro series rings with plasma-moly facing on the top ring I also ran that same ring set on my 598 bbc 700 shot of nitrous and they worked great 7.0s at 199 all day long now if you are blown or turbo I would go with the speed pro hell fire rings.Thats what I run on my twin turbo sbc on alky . oooya low tension for sure if you are running a vac pump hope this helps Troy C :D
ARUSSELL 10-08-2008 06:22 AM
For n/a on alky I would go with a plasamoly top ring and a low tention oil ring.
demented 10-09-2008 12:35 PM
I run Ackerly and Childs rings. I have run them for the last 5 years and have zero problems with them. I do run nitrous and alcohol but I know they make a ring for all applications.
http://www.akerlychilds.com/
