Push Rods
I'm replacing the cam in my bbc (468 -12.5 compression) with a comp cams solid roller, springs, rockers, etc. I need pushrods. I don't know what to order. The heads are ported GM iron heads. Any help would be appreciated.
Re: Push Rods
comp cams parts, and your not using there push rods??? whats going on here? i would stay with comp products ,its a safe bet |
Buy an adjustable pushrod or borrow one from a machine shop to mesure the legnth you need.
Zip. |
pushrods
Manley has 3/8 diameter with .080 wall or .120 wall.The 3/8 x .120 wall will be just fine.They also have 7/16 diameter.
A lot depends on the RPM you plan to run. You need an adjustable pushrod to figure out what length you need, this is one of the last things you do after the engine is assembled. Variations in cams, lifters, valve lengths, deck height, how much the heads are cut, gasket thickness, and the type of rockers all make each engine unique. You need a light weight spring on the intake and exhaust of one port to check, you want the line between the pivot centerline and the roller tip centerline perpendicular to the valve stem at mid lift. This will create the smallest arc across the tip of the valve which loads the stem the least. If you run standard rockers and guide plates you are limited to the guide plates as far as diameter. .080 is OK at 7000 or under, thicker is better at controlling harmonics and a good idea if you run it higher. If you run shaft rockers, as Todd suggested run the largest that will fit. Manton, Trend, and Smith Brothers all make quality pushrods, I run 7/16 .140 wall Manton in my SB2. I had quick service from Manton, ordered on Thursday and had them Monday.
| All times are GMT -8. The time now is 04:50 AM. |
