-   -   still using solids (https://www.racingjunk.com/forums/showthread.php?t=21928)
kbartley 09-26-2008 07:20 PM
still using solids
What do you guy's think about using a comp cams solid lifter cam. spec's: int..555/exh..555 110 lobe sep. installed in a 377 chvy w/ dart iron head's 64 chambers, 215 port's w/ 2.05 int. valve's. car weigh's 1700lbs. Kris
cepx111 09-26-2008 09:01 PM
Looks like a good cam for that set-up, whats your compression ratio?
If you can afford it go with a solid roller though, there is no comparison.
Cp
kbartley 09-27-2008 05:40 AM
Still running solid's
The car is an Altered w, 32 Bantam body. 377ci w/ .225th dome's. I run this car in a nostalgia class. Was actually thinking about running a little more lift due to the head's I am using. The car w/ a 5.14 gear run's low 6.20's off the handbrake in the 1/8th. I was thinking of moving up around .580-.590ish. I can do this safely. What do you think as far as a roller goe's would be a good choice w/ these head's? Kris
kwkracing 09-27-2008 02:30 PM
is it a comp magnum 285? i used that cam in ---a 383 and 406, very good cam.
kbartley 09-28-2008 04:16 AM
still using solid's
No, this is a 306s comp cam. I believe you are thinking about 285B-6 cam, possibly w/ .532int./.555exh.. Yeah that is a real nice piece. Kris
sg1586 09-28-2008 06:32 AM
Use the lifter with the lazer hole in the bottom. You can run more spring pressure and your cam will like it also....
zipper06 09-30-2008 04:16 PM
I ran this cam for a couple yrs. it worked great in a heavy car, lot's of low end and up too 7200rpm. Don't know how good it would be in a light car though. I spent close to $800.00 went roller and picked up less than a tenth with a .626 roller. Just keep the springs around 140lbs seat pressure and i agree with sg1586
on the pressure oiled solid lifters.
http://img29.picoodle.com/img/img29/...tm_39911ab.jpg
jmarksdragster 09-30-2008 07:45 PM
Look for a cam with a tighter LSA, 106 would be good. Lunati still has a good selection of on the shelf FT cams. Lift as much as the springs will hold. How much converter?
