-   -   Federal-Mogul lightweight pistons questions and specs (https://www.racingjunk.com/forums/showthread.php?t=21923)
hammerdamage 09-25-2008 02:39 PM
hello all, i have a nos set of discontinued lightweight federal mogul pistons with the part numbers of lw5020f and lw5021f. they are small block chevy pistons for a 383 stroker . i have little info other than the weight (448 grams), compression ( 10.5-1) and that they are 2618 alloy. if someone has an an old F-M catalog i could use some info like valve relief cc's,piston to cylinder clearance, compression height etc. i am building a new motor for next season and could use the info. thanks in advance for any info. gary
sg1586 09-26-2008 03:20 AM
Post that info on ST if no one can help you here..
