-   -   fuel lines (https://www.racingjunk.com/forums/showthread.php?t=21805)
amcjunky 09-08-2008 01:45 PM
fuel lines
ok so i am putting in my fuel lines at the momment.
my question is whats the best way to cut steel braid line? i was told to get a hack saw with a 32 or high tooth count and that would work fine but it seem that i get all the way threw just fine and at the end it always screws up. i use eletrical tape were i want to cut also.
the other question is any tips of tricks to get them to go into the actual fitting?
thanks justin
bbchevy 09-08-2008 02:32 PM
Line CUTTER!
I Make these LINES Daily!
CUT-OFF Wheel with a 4 or 5" Wheel!
I have Used every Type of Cutter Made,this works the BEST!!
Later
G 8)
Use as MUCH Lube as Possible,and i have some Super Thin Electrical Tape.
Also,Use ANTI-SEEZE on the Fittings!!!
hammertime 09-08-2008 03:51 PM
I also use some big cable cutters works great, just need to keep sharp.
topcat572 09-09-2008 08:39 AM
hose
The little cut off wheels on a 1/8 die grinder, cheap and easy. :)
Tod74 09-09-2008 08:54 AM
I never had no trouble with a hack saw but you gota tape it good...I use masking tape wrapped several times around. Also get a set of aluminum safe jaws for your vise that are made for the AN fittings...makes it easier.
kwkracing 09-09-2008 01:05 PM
4.5" angle grinder with a cut off wheel!
ARUSSELL 09-09-2008 01:12 PM
Spent the $4 and buy a tubing cutter
suicidebomb 09-09-2008 03:36 PM
I'm a cutoff wheel guy.
johnracer 09-09-2008 03:45 PM
Cutoff wheel here too....
shinyblackpaint 09-09-2008 07:43 PM
Cutting braided hose
Be hard to cut braided hose with a tubing cutter...............be kinda mushy/squishy/messy.
Best way is the thinnest cut-off wheel possible. I use a .045" thick wheel all the time after giving it a couple wraps of electrical tape. Really wouldn't even need the tape it cuts so neat.
