-   -   15x10 8lug wheel fit on dana60 front (https://www.racingjunk.com/forums/showthread.php?t=21760)
crankyanker454 09-03-2008 05:19 PM
JUST WANTED TO KNOW IF 15X10 8 LUG WHEELS WOULD FIT ON A DANA 60 FRONT GM, IVE HEARD YES & NO DEPENDING ON THE CALIPER.THANKS
bfoster 10-21-2008 10:25 AM
Depending on the backspacing they should fit, if not a small amount of light grinding on the caliper may be necessary. 15" rims fit better on a 60 than they will on a 44
kwkracing 10-21-2008 03:01 PM
yep steel wheels should fit, aluminum wheels are usually a little thicker and you might have to grind the caliper, but will also work.
