Starter Turns
I had a problem appear last Friday night at the local track. TThe starter motor turns the gear when power is turned on in the car from the disconnect switch and the power switch is not turned on in the car. It doesn't engage the flywheel, it just spins. Nothing happens when I hit the start button on the Painless panel. What gives here.
What kind of starter is it?
Re: Starter Turns
oops misread the post.
The way I understood his post was that the starter starts to spin as soon as the kill switch is turned on, but doesn't engage the flywheel. Just spins. If the solenoid is on the starter, the contacts in the solenoid are stuck together or something is shorting the batt cable to the lead that feeds the motor. Should be 2 big posts on the solenoid. Batt cable is attached to one, the other feeds the motor when the solenoid is engaged. The batt cable may be loose and shorting against the other post....
| All times are GMT -8. The time now is 08:12 PM. |
