-   -   oil pump problems!! (https://www.racingjunk.com/forums/showthread.php?t=21734)
ojpearce05 08-31-2008 05:22 PM
oil pump problems!!
ha sanyone seen a oil pump(M55) break off? It broke by the dail pin holes, the pump, screen, and oil pump rod was in the bottom of oil pan when I pulled it off. the top part of the oil pump was still attached to the block. It never made any noise, just noticed I had no oil pressure, and turned the engine off.Just wanting to know if anyone has had this happen or maybe what caused it. what it be good to go with a M55hv?
curtisreed 08-31-2008 05:29 PM
Melling has been having a lot of problems with their pumps breaking off. I believe you have to go with the select pumps for the good castings. They changed the std. casting to save money I guess. Go over to speedtalk.com and do a search about it. Lots of info on them.
Curtis
I972Nova 08-31-2008 05:47 PM
A friend of mine had a m55hv pump do the exact same thing. loaded it in the trailer ready to go and unladed the next week with 0 pounds of oil pressure..
Melling is just going down the crapper from what I have heard...
ojpearce05 08-31-2008 05:52 PM
Thanks for the replys. Just bought a new m55hv and gonna bring it back tomorrow.
promod45 08-31-2008 07:12 PM
oil pum
check out these pumps there bodys are made from 4340 steel and they have billet gears, can get them from competion produts
Tod74 08-31-2008 07:13 PM
P.M " US7RACE" on here or Motorsports Village...he has been through this problem more than once...not sure what he finally figured out but I think he did get it solved...
promod45 08-31-2008 07:14 PM
oil pumps
check out these pumps from cvr they are made of 4340 steel for there housings and you can get them from competion products......http://www.cvrproducts.com/steel_oil_pumps.html
us7race 08-31-2008 08:12 PM
Hey..Thanks Todd I have had that problem.. :oops:
I kept replacing the pumps with the older thicker casting pumps and even a BBC HV oil pump it help up until the crankshaft twisted in Half.
I believe what was happening was the crankshaft was cracked and causing a vibration in the motor.. It was a Cast steel crankshaft.
Since then I have swapped to their recommended pump..
http://data.melling.com/Select/small_block_chevy.php
And upgraded to a 4340 crankshaft. I think I put the cast one thru more than it's share of abuse and it failed it breaking off the oil pump was a sign and I didn't want to think that. If it was mine I would have the crankshaft magged and get one of these pumps. I use the 10552's.
jmarksdragster 09-01-2008 05:51 AM
Re: oil pum
He is talking about the CVR pumps, both billet aluminum and cast steel. Scrap the Melling.
Racefab57 09-01-2008 02:11 PM
The best oil pump on the market is a titan oil pump!! Ed at edvanced engines has em for 1/2 price to rjer's Got 1 myself from him!David, ps he's having health problems and could use to make a sale ,his articles and address is on this forum David,
