-   -   suspension help (https://www.racingjunk.com/forums/showthread.php?t=21675)
mark468 08-24-2008 05:50 AM
suspension help
http://s273.photobucket.com/albums/j...t=08081702.flv
all new cal trac set up ,mono leaf and 9 way adj rancho shocks ,28x10 slick,trans break blowing tires off as you can see,1/4 turn preload and shocks set to 5 ,60 ft was terrible 1.64,
any one cal trac exp please set me in right direction
us7race 08-24-2008 12:08 PM
How is the front suspension? It does not look like it is transferring any weight...
zipper06 08-24-2008 03:53 PM
X2
mark468 08-24-2008 05:49 PM
has comp shocks set at 90/10 front can be pushed down with minimal force ,it sits app 2.5 inches lower than the rear
zipper06 08-24-2008 07:19 PM
Do you have the torsion bar removed?, that will interfer with transfer, if it's still attached.
