How much horsepower on motor mounts?
Got a 68 Camaro backhalf car with a BBC around 675 h.p. on Moroso solid motor mounts and a stock trans mount. Thinking about upping my game this winter, possibly a 540 or triple nickle around 850 horse. When do you need to use motor plates and mid plates? Is there a rule of thumb?
I have a 540 in a NOVA with a 12 pt cage and I use the solid motor mounts, a rubber trans mount, AND a front motor plate.I did it to help tie the front together beter and control twist... There is no room for a mid plate in the car the way it is now....I used the solid mounts to locate the engine while I made the mounts for the front plate and then just left them in there.
A friend of mine has a 75 Nova with a Procharged 540, water to air intercooler. and 3800#'s. Dynoed at just under 1300hp and has run mid 8's on mounts just like yours. I'd have to say that's pretty much the limit.....
we twisted mounts on a dart headed Ls7 powered 69 big tire camaro (3240lbs) on a 300 hit...
this was in 98 or so...made 1000 hp on nos.. |
| All times are GMT -8. The time now is 05:33 PM. |
