-   -   JE Piston Tech (https://www.racingjunk.com/forums/showthread.php?t=21645)
ARUSSELL 08-19-2008 09:09 AM
JE Piston Tech
I am a Tech at JE Pistons and can help with any piston related issues or questions.
curtisreed 08-19-2008 09:58 AM
That's awesome, glad to have you here.
Curtis
hammertime 08-19-2008 10:44 AM
Re: JE Piston Tech
Have a set of pistons I cant figure out what brand they are , maybe you can help me here.
They are 4.560 bore for 555 # on piston 6243A6 is this your # or no ?
ARUSSELL 08-19-2008 11:23 AM
That part number 6243A6 is not one of mine but sounds like a Wisco part.
hammertime 08-19-2008 11:53 AM
thank you :D
FAT622 08-19-2008 09:50 PM
Hi,
I am building a 632 ci BBC N/A 14:1. Whats the difference between SRP and JE?
ARUSSELL 08-20-2008 06:35 AM
The SRP pistons are designed to be a sportsman level piston, where the JE is a full competion piece. The SRP is made out of a different alloy that is not as strong as the JE. The JE parts have more machining processes for a shelf part and have the ablity to be custom built to your application.
jmarksdragster 08-20-2008 07:14 AM
I am putting together a 460 SB2 head engine in a 9.5 AL Dart block. Our current thinking with the 4.25 stroke is to use a 6.3 rod with a 1.075 pin height (give or take depending on final deck measurement). Will that be the best to use for stability, wear, and reliability? Or should we look at a different rod length/pin height?
ARUSSELL 08-20-2008 08:37 AM
The SB2 head is a little trickey due to the fact the intake valve relif is pushed so far twards the edge of the piston. I would reccomend a little shorted rod like a 6.250 or even better a 6.200 to give more compression height and better ring placement.
iTiPerformance 08-20-2008 08:48 AM
Re: JE Piston Tech
[quote="ARUSSELL"]I am a Tech at JE Pistons and can help with any piston related issues or questions.[/quote
What about a -50cc dish on 1.100" CH? 4.125 bore. Running an Aluminum rod. :?:
