-   -   Throttle restrictors HELP (https://www.racingjunk.com/forums/showthread.php?t=21641)
vagtlmn 08-18-2008 09:30 PM
Does anyone know where I can find some device to restrict the movement of my throttle. I am trying to run a series that does not allow Throttle stops or any electronics. The only way I can see to run this is to restrict the operation of my throttle. I have seen a couple for 4150 and 4160 carbs but I have a dominator and need to come up with something in 2 weeks.
ANY IDEAS ????????????????
johnracer 08-19-2008 02:26 AM
I'd fab an adjustable stop under the throttle pedal......
us7race 08-19-2008 03:44 AM
I seen a BBC Camaro this past weekend at the track it was a 427.
Not sure what was all in the motor but sitting on top was a Holley 2bbl...
It had a homemade wooden spacer under it. So I had to ask the guy why and he said he runs the 6.50 index (1/8th) and needed to slow the car down..It had been running 6.50's all day long... :shock:
curtisreed 08-19-2008 03:58 AM
Restrictor plate under the carb. Easy to make you will just have to do some testing on sizing.
Curtis
suicidebomb 08-19-2008 07:05 AM
A guy I know just runs a bolt on his carb linkage, It prevents the carb from going to WOT. He adjusts it to his dial-in, and is very consistant.
CarbGuy 08-19-2008 10:01 AM
Make an adjustable stop for your pedal. Use a piece of all thread, with some jam nuts. You can than Control how quick the car runs by adjusting the length. DO NOT USE A RESTRICTOR PLATE UNDER THE Carburetor. They cause distrabution problems.
dak697 08-19-2008 05:53 PM
the adjustable bolt under the pedal works well.. When we ran SC back in the 90's there was an altered (injected BBC) and he used the same set up... He had it down that 1 full turn was .007 in ET
JimmySmith 08-22-2008 05:28 PM
I had good results with a vac carb and a screw to limit the sec opening, I had very good success with restrictor plates under the 2" spacer with out any bad effects and now I have Hilborn Stacks with the bolt deal in the acc petal and it is very easy to adjust. Later J. Smith 4621 racing sometime :D
jrdragsdad 08-24-2008 04:33 PM
can you use this http://www.jegs.com/p/Moroso/764313/10002/-1/10407
johnracer 08-25-2008 03:09 AM
Originally Posted by jrdragsdad
The problem with that style is that it put's a LOT of strain on the throttle cable/linkage when used to limit throttle opening. It's much better to limit pedal travel with an adjustable stop.
