-   -   Spark plug help/advice (https://www.racingjunk.com/forums/showthread.php?t=21638)
txarsenal 08-18-2008 04:58 PM
I am in need of some advice on a suggested spark plug and heat range to go with. I rcently changed over from gasoline to alcohol in my blown 540 BBC. I have an Enderle bird catcher on it and looking to my fellow alcohol tuners on where to start on with spark plugs. What would you advise on running and I know it has to be a couple of heat ranges lower than race gas, just need a starting point.
Thanks,
maxpower671 08-30-2008 10:32 AM
heat range for plugs
with NGK's, try heat range 9, should be close..
kwkracing 08-30-2008 01:35 PM
im running autolite 133 in my 468" blown alky
zipper06 08-30-2008 06:09 PM
Running NGK 9's in s/blk 1471 on alcohol.
dparker 08-31-2008 12:29 PM
NGK 8s or 9s seems to work best out here. Don't go to cold on alcohol.
