-   -   goodyear slicks (https://www.racingjunk.com/forums/showthread.php?t=21590)
br1984 08-10-2008 04:41 PM
goodyear slicks
info needed been haveing trouble planting right rear tire race last night 60 foot was up and down seen today my tires dots are gone from middle to in side the rest is abought 50% worst on right side could houseing be bent has fab 9inche ? or
shawnp 08-10-2008 04:53 PM
That is possible or it is possible the rear is not in square. I have never had a side wall issue that shows what you are seeing with the GY but have with M/T tires.
sg1586 08-11-2008 03:43 AM
unequal bite??? Does the car lean way over to one side??
Hove any vid of the back of the car on the starting line....This will help us help you..
br1984 08-11-2008 01:38 PM
goodyear slicks
no the car leaves even i posted wrong the slicks aer hoosiers not goodyears sorry
onedragracer 08-16-2008 06:17 AM
Have someone video your car making a pass. You can slow down the video while you watch it and that should help you find your problem. I bet your rearend is not square with the chassis like the guy above mentioned.
dparker 08-23-2008 07:58 AM
You said dot tires. Do you drive this car on the street? If so, and you have a spool, everytime you turn one tire must slip, even if your turning slow. And while your turning your car is applying more weight to the outside.
Bamfster 08-24-2008 12:21 PM
do you mean the wear indicator "dots" are gone? If so, that is a common symptom ( inconsistent 60" ) of worn out slicks.
br1984 08-25-2008 03:14 PM
goodyear slicks
yes but there just gone on inside never had a set do this before from center out still good
itsabird 08-25-2008 03:46 PM
how much air pressure are you running?
br1984 08-25-2008 05:32 PM
goodyear slicks
most of the time 61/2pounds
