No oil on right head
I fired my 434 sbc for the first time and I am not getting oil to the rockers on the right side. Left side got oil though. The oil pressure gauge said I was getting good pressure, but just not to that side. I am playing around with my alcohol inj. so I didn't have it running for more than 10 seconds (I am chasing fuel leaks). What do you all think? Run it longer and hope it comes up or am I missing something?
I'd run it with a drill if, it's wet sump ,until I had oil.
Thanks, thats something I didn't think of!
If you pull the dist. out and run a drill you will never get oil to the top of the block. the dist. housing completes the oil passage on the right side. Oil does take a while to get to that side for some reason. I always pre-oil everything in the valvetrain for just this reason. It may take a minute to get oil to that side of the block so just be patient but DO put oil on the rockers and valve springs for that time.
http://i237.photobucket.com/albums/f...4/100_0176.jpg |
I USED AN OLD POINTS TYPE DIST. AND WELDED A PIECE OF METAL ON TOP AND USE A DRILL. WORKS PERFECT.
RPC, sells them for under $20.00, and Speedway sells them also. I have one in stock, PT# S9534 but can sell you a hundred of them.
http://img29.picoodle.com/data/img29...2m_f7bed4c.jpg Zip. |
| All times are GMT -8. The time now is 03:50 AM. |
