-   -   INSTALLING RIM SCREWS (https://www.racingjunk.com/forums/showthread.php?t=21567)
lanham 08-07-2008 05:42 PM
Any tricks i need to know when installing rim screws.Will it mess up the bead on the tires and will it work alright with tubeless tires.Thanks
Tod74 08-07-2008 09:07 PM
MAKE SURE THE INSIDE SCREWS ARE IN LINE WITH THE OUTSIDE SCREWS.
john858 08-08-2008 09:39 AM
tod is right & they do make a tool to help with spacing.(i just made my own its cheaper)
ashtrak 08-10-2008 04:14 AM
make sure you use 1 of the screws to run in the holes after there drilled to give them some sort of tread in the rim. It will make for an easier job when tire is mounted.
lanham 08-10-2008 05:57 PM
rim screws
What is the formula to figure out the spacing.I was going to put 8 screws on each side.The rim is 15". Thanks
mytmouz 08-10-2008 06:23 PM
A wheel is a circle, a circle is 360 degrees, 360 dregrees divided by 8 rim screws = 45 degrees apart...
hammertime 08-10-2008 07:07 PM
Re: INSTALLING RIM SCREWS
dont use them :lol:
Tod74 08-10-2008 07:32 PM
dont use them :lol:
Hammertime what do you use? beadlocks? or Hightack? I consisdered using High tack on my new wheels rather than screws....never tried it before though.
hammertime 08-10-2008 08:22 PM
dont use them :lol:
I use neither, I mark them to start year and they dont usually turn it they turn i put screws in but more often then not they dont turn. 1.04 60ft best without turning at all, I've seen some turn 1/4 way in 1 pass though. its best to not screw mark then if needed screw
johnracer 08-11-2008 02:19 AM
I agree with David...
