Water in Head??
I dyno'd my motor last week. I have it in the garage with the bag over it. Tonight i removed a valve cover to install different valve cover gaskets and noticed small area's of clear looking water.. in a few low areas of the head. It doesnt look like a milkshake... is this just condensation or should i be worried.. the other head didnt look exactly the same. If the dyno was using just water would it look clear if there was some kind of leak??
thanks Keith |
Could be condensation, where i live it's so humid if you cover a motor with plastic, the next day every thing is rusted, even in the summer, i've got 2 blks right now that i have to clean or revat, from storing them in my shop over the winter.
Do a pressure test on the cooling system, if there is no leakdown, it's probably condensation. JMO Zip. |
water in head
I wish i could pressure test it... i havent installed it into the car yet since last weeks dyno session
Pull the drain plug and watch it drain...If there is water in the oil it will come out first |
Does the engine have head studs or bolts?
KW...
KW. i have heads studs no bolts...
are they leaking inside the heads? Maybe thats were this lil bit of water came from, i know they are bad about getting them to seal even when a good coat of sealer is applied. Just a thought. goodluck!
| All times are GMT -8. The time now is 10:28 AM. |
