-   -   anti-rollbar (https://www.racingjunk.com/forums/showthread.php?t=21551)
br1984 08-05-2008 05:43 PM
anti-rollbar
need info on how to set up car for rollbar i know how to mount it do you leave preload in car or take it out driver out right i heard driver needed to be in it i cant see how that would work ? thangs
gearhead1011 08-05-2008 07:11 PM
If this is a 4-link car I would leave one of the drop links disconnected until you have the suspension set up, including preload. This is done with the driver weight in the car. Then connect the drop link and set the anti roll bar neutral.
zipper06 08-05-2008 09:05 PM
Good :?: i want to put one on my car also, but i've had advice from a couple good sources that had installed them and then removed them. One a 66 nova s/blk that runs 8.60's he said the car never reacted the same 2 passes in a row, it kept binding. He had a powder coated shaft. So with that in mind i was thinking only to have needdle bearing shaft unit. But i too would like to hear opinions on the anti-roll bar installion.
br1984 08-06-2008 01:27 AM
anti-rollbar
it is a ladder bar car
gearhead1011 08-06-2008 03:47 PM
Re: anti-rollbar
I would still set it up the same way but ladder bars usually don't require an anti roll. Why are you installing one?
br1984 08-06-2008 05:28 PM
anti-rollbar
hi i have a 2/3 chassis vega it wants to turn right on starting line i have pre loaded it more then normal bought new coilvers springs changed tires no matter what you do it wants to turn it workes better if you let wheelie bars up a little if front comes off the ground it turns i would realy appreciate any help thangs barry
topsportsman1 08-06-2008 10:23 PM
In the chassis section there is some info on what you are doing,you may want to read this thread for ideas and help.
http://forums.racingjunk.com/viewtopic.php?t=2363
gearhead1011 08-07-2008 05:11 AM
Re: anti-rollbar
An anti roll bar is used to minimize body roll you wouldn't want to add one to try to correct the problem you're having. Follow the thread topsportsman linked to get the basics. You will want to check for anything that may be flexing or binding through the suspension's travel. I have seen a few ladder bar back-halved cars that the bars would hit the floor as the suspension would compress. You want to make sure the shocks aren't bottoming out too.
