HELP HELP HELP!!!
1990 corvette, starts, runs, when it gets warmed up stalls sputters quits. And won't stay running.
To be honest, if that is the original engine w/ the factory ECU, you are better off checking codes first... there are a mess of sensors on this car. You have eng. code on? This could be any # of faulty sensors to a bad cataletic convertor... needs to be hooked up to the correct software & searched for trouble codes. Good luck!
I AGREE --GET IT ON A MACHINE[ WITH SOMEONE WHO CAN USE IT RIGHT] AND FIND IT THAT WAY
LIVELY |
sputtering/stalling
a buddy of mine had the same problem with a late 80s vette it was the injectors good luck
| All times are GMT -8. The time now is 10:22 PM. |
