-   -   Procharger Motor build up Help (https://www.racingjunk.com/forums/showthread.php?t=21484)
dak697 07-28-2008 05:33 PM
I want to build a Procharger motor, but this is for a 9.90/10.90 Car. .
I would like some input on the motor program.
I would like to build a 480-500 BBC
10-1 pistons
Alum Heads
Alcohol Mechanical Injection
20 psi Boost
I know that most of these motors are low compression gas carb or elec fuel injection.
Do I build the motor like our Blown SBC Top Dragster deal.
Alum Rods, 11.5-1 pistons
Or
Can I/Should I build it with good steel rods and a good crank
What do these guys with 565 BBC and 12-1500 HP have for internals?
mudjeep 07-28-2008 07:20 PM
If it were mine it would have at least 11.5 for compression and aluminum rods, but you could probably get by with steel rods at that power level
