-   -   will a 66 nova coupe doors work on a sedan (https://www.racingjunk.com/forums/showthread.php?t=21475)
robabernathy 07-27-2008 05:27 PM
if someone would help me out it would mean alot, could i buy coupe doors and put the window frame off my sedan doors and make them work, i have a 66 sedan and finding the doors are almost impossible but if i could do alittle cutting it would be alot easier, and cheaper i can buy new shells just not with the window frames for the sedan
any info would mean alot,
thanks for any help
Robert
Oldewalnut 11-07-2008 04:59 AM
Can't directly answer your question. These people might be able to help. Call Chevy II's Only in Taylorsville, Kentucky (502) 239-8487. They have a world of stuff and could tell you what will and won't interchange.
Good Luck.
Tod74 11-07-2008 05:09 AM
I bet they are different but I don't know for sure...the reason I say that is , look at the Chevelle vs El Camino.
El Camino is based off of the chevelle wagon..same car really..There is even a cover you can take off to reveal what would be the rear floor of the wagon. the camino has sedan doors and the windshield is different so I would think that means the "cab"( if you want to call it that) is not the same shape as the hard top. jmo(guess)
I base those comments on the 1967 model because I have owned two of them ...I don't know about the rest of the years.
W31350 11-07-2008 05:14 AM
will not fit
