GM CRATE ENGINE CAM QUESTION
I'm wondering if you can order a different cam in a gm crate engine? I'm wanting to put it in a pulling truck..if so what cam would you advise? the motor is the 454 HO thanks!
I think you can, i know i was going to order a gm crate v6 and wanted
to change the cam myself and that would void the 3 yr warranty, you would have to order it from the manufacturer or from the dealer, scoggins-dickey was highly recommended for crate motors and they are very helpful, if you order with a bigger cam im sure it will have the warranty intact, good luck :wink: |
| All times are GMT -8. The time now is 05:15 AM. |
