-   -   406 s10 powerglide or th350 or gear swap (https://www.racingjunk.com/forums/showthread.php?t=21345)
CHEVYMATT 07-12-2008 09:11 PM
I HAVE A 406 SBC IT HAS DISHED PISTONS TO MAKE IT A 10.25 TO 1 CR IT HAS 5.7 HBEAMS.MOTOWN 220 HEADS AND PORT MATCHED INTAKE. 253/261 @.050 WITH 585/595 WITH 1.6 ROCKERS SOLID FLAT TAPPET
I CURRENTLY HAVE IT IN A 2800-3200 LB S10 WITH A POWERGLIDE AND 4.10 GEAR WITH 4500 STALL.
MY PROBLEM IS SHOULD I INSTALL A TH350 OR JUST RUN A STEEPER GEAR.4.56OR 488 I FEEL THAT THE 4.10 WITH A GLIDE AND NO NOS IS JUST HURTING ME.I WANT IT TO RUN THE BEST 1/4 MILE ET THAT I CAN. I JUST STREET DRIVE AND TEST AND TUNE . NEVER RUN FOR MONEY JUST ENJOYMENT.
PLEASE GIVE ME SOME ADVISE . THE GEAR IS THE EASY WY TO GO.
zipper06 07-12-2008 10:16 PM
May not be the answer you want to hear, but i have a friend who has a S10 with a 383 and 350 trans, 410 gears. drives it everywhere and to the track. It runs 11.60's on motor and with a 150 shot of nitrous it runs 10.80's on drag radials.
CHEVYMATT 07-13-2008 05:10 AM
well doing a tran swap in the truck will only take 2-3 hours but i still have to build the tranny. but i have enough tuff parts to make a nice manual shift th350 but if im going to shell out cash for a manual valvebody i might want to try a tbrake just for the hell of it..
this engine ran a 11.78 in a 77 firebird with th350 and 4.11 but now ive installed 1.6 rockers to get my lift to 585.595 and i bought a motown 220 intake and an electric waterpump..the truck hooks good . i had 1.52 60foot last year with an old 406 combo. more than likely i will throw togeathger a budget th350 and se how long it lasts. ive had good luck with junk th350's.
thanks for the advise
Racefab57 07-13-2008 12:30 PM
The turbo 350 has a steeper first gear I believe than a glide .That should help 60 ft it . You may have to do a gear change too or as you say your just having fun with it try the trans change. Do the trans brake their FUN!!!!! David
bbchevy 07-13-2008 03:23 PM
Trans?
Get YOUR Wallet out,when you go to Purchase that T/Brake for the 350!!!
Heres My Advise?
1st of all???How tall of a Tire?
If you have less than a 28"Tire,keep the 4.10 and go to the 3-spd.
Bigger Tire(Depending)?
Leave the Glide in,Loosen the Converter,and either the 4.56 or 4.86?
Lots of UNKNOWNS Here?
Hope this Helps?
Later
G 8)
jmarksdragster 07-13-2008 06:13 PM
You will probably find the 350 is slower. Leave the glide in.
CHEVYMATT 07-13-2008 06:33 PM
thanks
i have a 28/12.50/15 et street .
my thoughts are to try the 4.88 gear and bring her out hard . my convertor is about 4500 but when cruising at 2700 rpm and whack the throttle it flashes to about 48/5000.
im not sure on the rule of thumb but i have a 12.5/8 inch long input turbo spline and i was told that that is a 1.82 first gear. the trans is a tci competition built by tci with manual forward pattern. i was told that a 12.5/8 long shaft ment it wasa 1.82.
a th350 has a 2.52 first gear i believe
th400 has a 2.42 .
thanks for the responses
