-   -   Chev 283 Steel crank with no dampner thread (https://www.racingjunk.com/forums/showthread.php?t=21331)
jrthone 07-10-2008 11:40 PM
Do any of you guys know how to attach a crank balancer to a 283 Chev steel crank. It has no thread for a bolt??? What do i do???
zipper06 07-11-2008 01:04 AM
Your only option is to drill and tap a 7/16"X20 hole about 1 1/2" deep. None of the early 265"/283" cranks had drilled snouts they were all press fit balancers.
poncholvr 10-27-2008 10:25 PM
THOSE CRANKS WORTH ANYTHING?
zipper06 10-27-2008 11:38 PM
The steel one's make good 302/331" high reving engines.
Tod74 10-28-2008 04:26 AM
I had a LARGE JOURNAL 1178 DZ 302 crank ..it had never been in an engine...my father had it rat holed in his shop all these years..it was still in the GM box until it fell apart...he gave it to me last summer .. I sold it on EBAY for over $900
desoto30 10-29-2008 11:35 AM
They used to be plentiful & cheap & I've made good 302s from them Never used them in 4.195" bore to make 331 cubes but that'd be a cracker combo for sure
ARUSSELL 10-29-2008 02:12 PM
With that bore BUZZZZZZZZZZZZZZZZZZZZZ
zipper06 10-29-2008 03:41 PM
When you look at it, Nascar is doing esentually just that, they are running 3.2 stroke cranks with 1.880 rod bearings with 6.2 lg rods in the 358"motors and no one can question that they run 9,000 rpms for 500 miles with few failures. The other factor is that is not much torque but a ton of HP, so a light vehicle such as a dragster or 2,000lb roadster would be haul ass. In fact we're looking at trading the 66 3700lb Biscyne for a 1934 chev roadster with a 306" s/blk that runs 8.18 in the 1/4 mile, but my friend don't want the engine he wants to stick with his b/blk and let the guy keep the motor (high maintenence).
Racefab57 10-30-2008 12:58 PM
Zip, HI,I destroyed a 298 sbc at 11000rpm yrs ago,what a mess but what a FUN ride while it lasted!!!! D.R.
ARUSSELL 10-30-2008 01:46 PM
We did a 295 4.030X 2.900 comp elimator engine would be fine at 12000 but when when we changed gears it let fo at 13500. Same thing fun ride while it lasted.
