-   -   How much HP?? (https://www.racingjunk.com/forums/showthread.php?t=21328)
altune 07-10-2008 07:43 PM
How much HP??
I am tryin g to determine a base line on an engine combo I am building.
It is a sbc, dart 4" stroke, 4.155 bore, 14.5-1 compression, heads that flow
350-355 cfm @ .700.
it is alcohol injected and also vac pumped.
drag engine.
Engine is new.
here is what I came up with:
engine alone 720 hp
alcohol injection 5% + 756 hp
vac pump + 35 hp = 791 hp
am I close?
cepx111 07-10-2008 08:04 PM
Pretty close I'd say. A dyno will tell no lies though.
Later Cp
hammertime 07-11-2008 02:28 AM
Re: How much HP??
350-355 cfm @ .700.
drag engine.
Engine is new.
engine alone 720 hp
am I close?
I'd say you are close, but we usually see 15-20hp for vacuum pump. Seen 45hp for injection.
altune 07-11-2008 02:19 PM
It's kinda what I figured.
Close to 800 hp.
Possibly a bit more or a bit less
I have also a morroso oil accumilator and running less oil in crankcase.
no dyno's in my area
crap
Al
