-   -   for super gas cannot get a good lite (https://www.racingjunk.com/forums/showthread.php?t=21318)
cs 07-08-2008 06:09 PM
have a s. gas bodied car and can not get close to a good lite
have nothing in box
have a 5400 convertor ---sbc approx 690 hp --car weights 2200 lbs
leaving at 4800
works good on a 500 pro tree----but last dog at a 400 pro tree
need some suggestions :oops: :oops:
topcat572 07-08-2008 06:25 PM
lights
Are You running a Pro tree brake?
cs 07-08-2008 06:53 PM
yes
us7race 07-09-2008 04:06 AM
Are you heads up racing? I run a BTE Bracket brake..I done some of this on a .400 tree and had alot of fun. I always left as soon as I seen any yellow and could cut between .030 and .060 lights pretty consistantly. I did move my transbrake button to the shifter for a 1 finger operation.. :lol:
sg1586 07-09-2008 04:23 AM
Old car??? Could be your set up or an worn out car........
Tod74 07-09-2008 05:22 AM
Have you tried going in last and leaving on the stage bulbs? :P
Why is it better to have the button on the shifter vs the wheel? other than to prevent accidentally hitting it?
curtisreed 07-09-2008 06:46 AM
CS,
I think this is something that will be hard to diagnose on the forum. It could be something a simple as a slow button, needing stiff wall slicks, etc.... Or you could be needing a fourlink change. Some things to look at are, tying down your front end, check for slack in your suspension, do not use a relay for controlling the trans brake solenoid if you are, look at the length of movement on your button, try putting some weight to pop the front tires up out of the beams or four link change whichever, shorter front tires. See where I am going with this, there are many, many variables and they are all different on each chassis. Are you needing to pick up a couple of hundreths or six or?
Curtis
cs 07-09-2008 10:30 AM
THANKS I AGREE--WE CHANGED BUTTON ECT
THIS IS A CHASSIS CAR ALL ELSE WORKS GOOD RUNS 8,S IF WE WANT TOO
WILL TRY GOING OFF CONVERTOR OR STAGE DEEPER WHO KNOWS
JUST THOUGHT I COULD GET AN ANSWER OF SOMETHING WE OVERLOOKED
I972Nova 07-09-2008 01:36 PM
Leaving on the converter should be good for a little bit, I usally have to add .015 to my box from the chip to the converter. On my dads car we had to run a REALLY short tire 22" to get it to go minus on the tree.
How far off are you? Staging deep can be very inconsistent.
cs 07-09-2008 04:01 PM
high 30,s is as low we can go
cannot go lower on tire due to getting in out of trailer
going to try on convertor and stage deeper ---can only go red ha ha
thanks
