-   -   coil over setup (https://www.racingjunk.com/forums/showthread.php?t=21317)
fishman1 07-08-2008 04:53 PM
coil over setup
This http://www.speedzonemagazine.com/zon...4-07-08-19.htm
a link to see my car hooking up......need some opinions on things to do to get consistent 60 foots as they go from 1.4 to 1.51 in same day.all over the place never consistent
Right now on rear coil overs i have passenger side shock on number 6 and drivers at number 5.....should i try softening it up by one click.but i am scared that the front end stay up to long and will slow down the car...these are just my idea no proof......tell me a few of your ideas.....thanks in advance
gearhead1011 07-09-2008 06:17 AM
Video would tell more about how the car is leaving but smoking the tires when you leave is a pretty good indication that it's spinning the tires hard. There's no way you can be consistent with that much wheel spin. There are too many things that could be wrong with your set up to start listing things. How about more info on your car? Tires, pressure & temp, suspension (ladder bar or 4 link) instant center, corner weights, type of shocks, front suspension including free travel. You said it 60's 1.4 to 1.51, how about the rest of the run? do you have all the incrementals? At least the et & mph.
itsabird 07-09-2008 07:48 AM
as stated by gearhead, a little more info, or video would help, going from 1.4 to 1.51, short time is a fairly big swing, if that is tire smoke i see in the photo, i would say that you are hooking, and unhooking caused from hitting the tire a little to hard. if you have double adj, shocks try stiffening rebound, if not try more air press.,
edvancedengines 07-09-2008 08:01 AM
That is exactly what I see too.
Initial tire downward pressure to violent causing tire to basketball upward and brek traction momentarily is what I am seeing here.
DRop ladder bars one full hole and at same time loosen extension dampening on rear shocks. Yu may even have to tighten them up agin by some. I always re-adjust shocks after moving bars so the change is not as
If 4 link do the same with shocks but move Instant Center Down or Down and Forward next holes. The car is hooking too hard.
Ed
fishman1 07-09-2008 11:18 AM
The car has 32x14x15 tires and i run usually 6.5 to 7 psi for pressure
that run in the picture is 6.5 psi....i don't feel any wheel spin in the car, my son says it isn't spinning but doesn't mean it isn't........as far as going up in tire pressure what do u recommend............
front shocks are 90-10 drag shocks
back shocks are only one postional adjustment
car is a ladder bar car with setup in middle hole
the car is front end heavy when we scaled it 55% front and 45% back
car weight is 2665 with me in it
car ran best time of 10.13 @ 130.56 mph in ok air
last weekend wasn't a good test had a few other issues and the air sucked friday air was 5600 feet and rh was up to 85 % at one time and most of the weekend was around 45%..........i greatly apreciate your input as i think the suspension is the hardest thing to figure out unless u have somebody knowledable watching and filming.........as i don't so i depend on your input.....any more input would be great
the times it runs will change up to 1/10th in the day depending on my 60 foots though and the mph falls only a little maybe 1 mph at most
itsabird 07-09-2008 12:04 PM
ed,s explaination, of chassis adjustment would be the cure, the key, being the softing of the hit on the tire, short of that, the trick is to keep tire from being smashed, sometime you can do this with air, i would start with 8 psi and go up or down from there, i am thinking up, but testing is the only sure way to tell, good luck and post result,
Racefab57 07-09-2008 04:29 PM
Ed is the MAN at this!!! I agree, try more air in tires, play around, Next drop that 1 hole in the ladder bars in frt!!!! GOOD luck, David
fishman1 07-09-2008 04:32 PM
For sure i will try more air pressure, it's free so a guy always trys something free first....lol...... i find the guys i race with most have no idea how the suspension works and myself i have little knowledge on this, this is my 3rd racing and i was green ....i have learnt alot but alot further to go
So if i stiffened up the rear shocks a couple clicks would this stop the tires from getting hit so hard to?
us7race 07-10-2008 02:17 AM
Your shocks control how fast your suspension hits your tires. Your Ladder Bars will determine how hard it hits them.
fishman1 07-10-2008 11:23 PM
thanks for the input i will try 8 psi in rear tires and go from there.
Do you guys think that my front shocks are to loose to as i am usuing 90-10 drag shocks maybe ineed some stiffer shocks up front....thanks for input
