motor pops through the exhaust
trying to time my motor ,but it kee4ps popping through the exhaust.
big block ford 460,any help would be appreciated |
timing
If You think the timing is close, 1st thing I would do is compression check it to see if anything is funny in the valve train. 8)
i got 220lbs of cylinder pressure
220 lbs on all 8 cyl??? I would pop the valve covers off and see if any rockers are loose to indicate a prob with cam or lifters.
My 468 chevy was popping through the exhaust, I took the valve cover off and found about a quarter of an inch valve lash. This was the result of a broken lifter that wiped the cam lobe... |
hey josh everything was fine in the valve train, it wound up being my cap & rotor. thanks for your input.
| All times are GMT -8. The time now is 02:53 AM. |
