-   -   new msd 6a box problem (https://www.racingjunk.com/forums/showthread.php?t=21197)
cbtlr 06-25-2008 12:25 AM
New 6a box matched up with Flamethrower hei distributor.Engine ran well before the install.Now the engine hesitates when reving up.I know of this prob with the 5 and 7 pin module in the distributor.There is a resistor that is needed to correct this prob for the 5 and 7 pin module.My module is a 4 pin and has the stumble,hesitation of the 5 and 7 pin.Any ideas why I have this problem?Thanks.
jmarksdragster 06-25-2008 06:27 PM
Take the module out, run the pickup coil straight to the MSD. You don't need the module.
cbtlr 06-25-2008 08:57 PM
Mechanic did not remove the module on install.Wired up for 4 pin and I made sure module was removed.Car idled fine and would not turn off when ignition is in off position.Wired the diode in and problems solved.Whom so ever purchase a 6a box for gm hei 4 pin module.Make sure you order pn 8860.Your going to need it.I was lucky the local speed shop had the part in stock.
