-   -   Who makes a good old school swp sbc alternator bracket??? (https://www.racingjunk.com/forums/showthread.php?t=21192)
gungho 06-24-2008 05:04 PM
like it says i need a good old school alt bracket for my nova,i cant use the low mount on the left due to the tube chassis and the vega steering box,and the one on the top left with that long banana bracket is just plain gross and it spits off in the 7k range, any help would be great,thank you
promod45 06-24-2008 06:40 PM
bracket
first of all what pulley do you have on alternator you need the deep groove one that will stop spitting belt and second if you dont like long bracket just cut it reweld it and make it shorter if not what i have done alot of is mount altenator on bottom but i weld brackets to frame and put the slider on the motor and this works great as i never have it in the way and when i pull motor i just roll it away never take it off car...
68bbnova 06-24-2008 07:53 PM
I use a March Performance. You can just see some of it in my Racespace pictures. I think it is P/N 20130, but will look for the paperwork to be sure. I tried the passenger side mount one for the SWP, but the belt hit the lower radiator hose :!: It is a very nice piece, and no belts throwing at 7400 RPM.
gungho 06-25-2008 03:23 AM
how did they do it back it the late 60's with the 302's and the high reving destrokers like mine? I want the engine bay era correct like I built the car
http://imgcash2.imageshack.us/img529...2234xl0.th.jpg
mytmouz 06-25-2008 07:10 AM
With that big ol' banana bracket that you don't like...
fishman1 06-25-2008 12:58 PM
i am usuing the top notched belts and they don't come off, before i was usuing the bottom notched belts and they wouldn't stay on mine is a dayco
