Engine
I have a 468 motor and last night at the track I noticed a light film of oil on the inside of one of my zoomie hearder. Can someone tell me what this might could be? :(
Thanks Ray |
If you have a header evacuation system it could be sucking oil out of the valve covers especially if you dont have baffles under your breathers.
>Cp |
>Cp Might be sucking oil through the guides if you don't run valve seals. Might be sucking oil through the rings if you run low tension rings. Have you done a compression check on that cylinder yet? |
Could be Blow by from a ring not seated.
| All times are GMT -8. The time now is 09:16 AM. |
