-   In The Pits (https://www.racingjunk.com/forums/forumdisplay.php?f=18)
-   -   Line Lock??? (https://www.racingjunk.com/forums/showthread.php?t=21093)
Scooterz 06-13-2008 07:12 PM
Line Lock???
I have a electrically disconnected line lock on my car that is still hooked up to the front brake system hydraulicly. All I think I have to do is put the handle/switch on my shifter & wire hot/ground... I think. Anyways, does anyone use line lock to launch?? Is it possible to accidently have a caliper stick when you touch down & veer L or R?? Should it just be used for burnout/stage? It's a footbrake only car... it still has the working brake pressure gauge hooked up too... I may as well use it I guess, but I feel cautious not having one before. Thanks!!
gearhead1011 06-14-2008 12:03 AM
I use mine to launch. It's a stick car and I have to use it to keep from rolling through.
fla1976 06-14-2008 04:29 PM
line lock
The line lock is safe, just be sure to use a momentary switch. Do not use a regular toggle switch. You want it to work only while you hold the switch down. I have a friend who used a toggle and he forgot to release it and took a hard left when it touched down. Tore up the left front fender on the wall. :oops:
Scooterz 06-15-2008 09:39 AM
Thanks, I will use a grip w/ momentary switch. Never using it before, I just wondered if one caliper could ever stick or something.
fla1976 06-15-2008 02:52 PM
Line lock
As long as the calipers are in good condition you shouldn't have any problems. If they are sticking now, replace or rebuild before you run it, even without the line lock. Better safe than sorry.
Scooterz 06-17-2008 10:53 AM
Copy. Thanks for the help!!
