-   -   Tranny Gears (https://www.racingjunk.com/forums/showthread.php?t=21089)
ashtrak 06-13-2008 05:00 AM
Tranny Gears
I was wondering :? if you can run a straight cut gear (PowerGlide) on the street or are they more for racing. Advantages of the straight cut gear as opposed the others. Any help would be greatly appreciated :wink:
john858 06-13-2008 06:28 AM
straight cuts are alot stronger & some have stronger output shafts.i would think you could run them on the street ,they would a little noisey i would think.imo if your not running over 700hp just run a stock set of 1.76's.good luck
tkilby 06-13-2008 02:07 PM
Most of the straight cut planetaries have 9310 gears which are softer gears to absorb impact for drag racing. IMO, they would not be suitable in a street application. Again, IMO.
jrthone 06-14-2008 06:34 PM
Are straight cut gears( say a 1.80 ) in the glide noisy at all????? Evan if they are softer why couldnt you use them in a street application. On that note if its not over 700 hp i wouldnt bother spending the cash and just use a 1.76 standard set as they are very strong units.
tkilby 06-15-2008 04:23 AM
9310 is what is used in a "Pro Gear" ring & pinion set which is not recommended for street use. But after doing some more research, I found that in some of the high end manual transmissions street and race 9310 gears are used. So, in other words I don't know.
