-   -   What happens if you accidently push the trans brake button?? (https://www.racingjunk.com/forums/showthread.php?t=21059)
Xrated1 06-10-2008 05:29 AM
I'm new to a trans brake and just moved my button from the dash to the wheel. Got to thinking, what happens if?
3dracing 06-10-2008 05:43 AM
If you don't have the transbrake lookout in your delay box it will engage the brake.
Steve
Xrated1 06-10-2008 06:02 AM
I figured that, then what?
kw89425 06-10-2008 07:12 AM
can you say lock
OneBadGMC 06-10-2008 07:45 AM
Well, if you do it going through the lights, plan on watching the transmission exiting the passenger side door.
john858 06-10-2008 08:45 AM
your rear tires will have flat spots in them :(
sp2816 06-10-2008 09:07 AM
Some transbrakes will activate reverse when it is in high gear and others will only allow for it to activate while only in low gear. The transbrake in my car is a full-tree brake that will not activate reverse when it is in high gear (I just tried it). You can check that out the next time you start your car. While sitting still, put it in high gear and push the button and see if it locks it into reverse and high gear at the same time.
While it might not be best in some people's minds, I have had my line-lock/transbrake button on the steering wheel for over 15 years and have never bumped the button by mistake (it could always happen).
Bill Mitchell
gimmemud 06-10-2008 09:30 AM
Most will not do anything when trans is not is first gear, the transbrake locks first and reverse, I have only ran powerglides with brakes cant speak on anything else. The only thing that happens if mine is accidently hit is the nos is cancelled.
TheRabbit 06-10-2008 03:19 PM
Bill Mitchell
WISH I COULD SAY THE SAME. :oops:
think it's bad in a car, do it in a 4 wheel drive! :oops: :oops: it makes u feel stupid, but good thing for the 5 point harness. :lol:
I've hit mine several times with my right forearm when turning around kinda sharp.
demented 06-10-2008 03:36 PM
I've seen some 4x4's do a complete 90 degree endo on the front wheels. :shock:
That's when you hear someone in the crowd say" Kids don't try this at home"
