holley vs. quickfuel alky 750 carbs???????
i'm setting up my sbc bracket car to run on methanol & need advice on carbs. i was looking at holley & quickfuel and was wondering about the proform center that qf uses. any suggestions/info??????? thanks, brian
Re: holley vs. quickfuel alky 750 carbs???????
ww.apdracing.com & Pro Systems comes to mind. just my 2 cents |
ruppert & apd is what i use, you need to buy a carb or send one off and have it built for your engine.you'll be alot happier.good luck
hammertime,are you talking about the 950hp holley?
oh! :oops: ,my motor guy told me that quick fuels are a waste.he told me on the dyno a stock untouched holley will make a lot more hp that a quick.
I've seen it proven over and over at the track he is correct :D |
Alky Carbs
I would say go with Pro-Systems !!
| All times are GMT -8. The time now is 04:01 PM. |
