-   -   6 to 10 point cage?? (https://www.racingjunk.com/forums/showthread.php?t=21036)
prostreet1972 06-08-2008 01:12 PM
I have a 72 Chevelle that is back halved and currently has a 6 point cage in it. The main hoop, 2 bars back to the rear frame and 2 bars going diagonal from the main hoop to the front crossmember of the back half. It is used for drag only and I want to install a 10 or 12 point cage. Problem is I can only find 8 to 10 point conversion, don't know where I can buy just the bars that run diagonal along side the doors and I also need the bar that runs horizontally across the main hoop. I work at a hydraulic machine shop and asked the boss how much the metal would cost and it was more expensive than if I just buy a full 12 point cage and just have extra parts. Can anybody help me out? Any company out there that will just sell parts of a cage?
Thanks,
Travis
promod45 06-08-2008 01:19 PM
bars
i would try chassis works and ask for mike he should be able to help you out if not try tim McAmis but he is alot higher in price. Is you car moly or mild steal, not that it mater just currious is all
prostreet1972 06-08-2008 01:20 PM
Thanks for the suggestions. It's mild steel.
john858 06-09-2008 09:34 AM
if contact a company to buy that conversion they would sell you the other two bars you need for alittle more i would think. good luck
lasttry 06-19-2008 03:05 PM
I've had good luck with Competition Engeniering...
