-   -   solid lifter & adjustment (https://www.racingjunk.com/forums/showthread.php?t=21032)
Scooterz 06-08-2008 07:56 AM
I am new to solid lifters/adjusting... a little green on motors on some things. I noticed a sound that was almost like a dead cylinder only @ low rpm. I checked all electrical first & plugs & wires. Checked for vacumn leaks... so far, so good. Next, I pulled on valve cover off the BBC. It had a slight stumble off idle & the low-end/rpm was not right... it had a classic valve failure sound. It has Milodin roller intake rockers & one of them was too loose (Builder says both int/exh are .26) the poly-lock had come a little looose it was probably @ about .80 or more. I adjusted it back to .26 & inspected all the others for tolerance, they were ok. I am very new to adjusting valve lash... would above cause that much trouble? This is mainly a street car/toy. Sympton started @local cruise here when I went home. Anyone ever have those poly-locks come loose? I bought a remote starer switch too, that was a big help to check the valve tolerance. Any advise on adjusting solid lifters before I finish this job???? Thanks gentlemen.
mytmouz 06-08-2008 08:02 AM
A properly adjusted poly lock may sometimes work loose. However, it it does it again, I would look for a lobe failure issue...
Scooterz 06-08-2008 08:34 AM
Thanks TPorter. If it is a "lobe" issue, I guess I will be forced to learn ALOT more about internals /eng. building soon. This symptom I had sound par for the corse when it is loose? One valve being off that much makes for crappy idle/off idle & sound?
mytmouz 06-08-2008 08:53 AM
Yep, it only takes 1...
OneBadGMC 06-08-2008 09:16 AM
Poly locks suck. If you don't tighten them enough, they come loose. If you over tighten them, they break when the motor gets hot.
Buy a stud girdle and be done with it. MUCH easier to set valve lash and it ties everything together for strength.
Scooterz 06-08-2008 10:42 AM
I wondered about a girdle... the poly that came loose is one that I must have overtightened... it is a replacement I had to install. I think I will look at a girdle... it makes sense. Any do & don'ts? reccomendations?
olds48 06-08-2008 10:54 AM
Just make sure the engine is up to temp when you adjust them.After you do one side,usually have to warm it up again to do the other side....that is if you're slow like me.Competition Products has some good deals on girdles.Only place I could find that had some that would actually fit my Canfields.Ordered 3 other sets from three different people.All 3 sent the exact same girdles.Last two guys I told them what I had tried before,and didn't work and they sent those anyways. :twisted: Do you know how much it sux to buy 3 sets of girdles,with 3 shipping charges and know you're getting screwed??ALOT :lol: Nothing like having enough $$$ invested in wrong stud girdles to afford a good shaft system :lol: Run the girdles.Can't do nothing but help,and you know they'll never wear out!A loose poly-lock floating around in a motor can quickly negate a couple hundred bucks spent on a good girdle :shock: Peace of mind is nice,too.Good luck!
OneBadGMC 06-08-2008 12:10 PM
http://jomarperformance.com/catalog/...cPath=21_22_26
http://store.summitracing.com/egnsea...=KeywordSearch
Scooterz 06-08-2008 12:15 PM
Mr.Olds48, I always enjoy your replies... thanks bud. I will probably have better luck scoring the girdles for a BBC. It has Crane/Mildonin rockers all w/ poly's. I haven't known the difference in the past to know better. I will warm it up good on the adjustment so I don't break another. I am amazed how one poly giving up tolerance can make it run so crappy in the low!! It is night & day....
rk85racing 06-09-2008 02:22 PM
poly locks
stud girdles r a good idea but if u kno what ur doin poly locks do the same job for cheaper. i check mine after every serious race and have had none come loose. if u want to save money just snug them up, u dont ahve to tighten the piss out of them.
