Internal balancer??
Im after an Internally balanced balancer for my set up and just wondering what you guys have run in the past or recommend. 632 BBC Dart Big M Ohio crank Ohio rods Wiesco 15.5-1 pistons BB3 Xtra ported heads Methanol injection bird catcher on Victor 2-R Tunnel ram.jesel dry belt drive 850 lift roller cam.MSD Crank trigger with 7AL-2 . 1.76 glide with 4500 converter. Thanks
I run a ATI super dampr on my 540...but have also used fluidampre in the past...nice balancer. Don't get a cheapo in my opinion.
What about Pioneer. Are they ok?
Not trying to hijack this thread or anything but what is the benefit of putting a fluid dampner ( balancer ) on a rotating assembly that's already been internally balanced?
The balancer is just neutral anyway correct? I thought they were only of benefit on a motor that was externally balanced? Learn me. Cp |
ATI the only way to go IMO
broken record :) ,don't waste your $,buy an ati
quik ? is that 176 tran stock? if it is your going to mess some stuff up!
The balancer is just neutral anyway correct? I thought they were only of benefit on a motor that was externally balanced? Learn me. Cp Curtis |
| All times are GMT -8. The time now is 05:34 PM. |
