-   -   Leaky Glide? (https://www.racingjunk.com/forums/showthread.php?t=20988)
jmech 06-03-2008 06:49 AM
Leaky Glide?
I run a 176 glide with a Hipster pro brake and 8" Coan 6000 stall converter. I'm running a deep pan and big cooler. There is no leak at idle but after every run it drips on the passenger side. The cooler lines are not leaking. I'm thinking its coming from the vent. I've tried running it on add but it makes no difference. Do i need a catch can for the trans? Is this a common problem? I no nothing about transmissions. Any help would be great. Thanks...Jeff.
Tod74 06-03-2008 07:13 AM
DO YOU HAVE A TRANS TEMP GAUGE? ARE YOU RUNNING A COOLER OR ARE THE LINES LOOPED TOGETHER?
jmech 06-03-2008 08:50 AM
I don't have a trans temp guage. I'm running a big B&M Super cooler with fan.
john858 06-03-2008 10:40 AM
sounds like your trans case could be cracked. that is a common place for them to crack right by the line & it wouldn't show up until you got on the brake. what kind of motor & trans mounts do you have.what kind of fluid do you run.
jmech 06-03-2008 11:53 AM
I'v cracked a case before in a different car. It had a huge leak compared to this. There is no huge leak on the starting line or the track officials would have told me. I get on the trans brake in the shop and no leak. I know its on the brake longer at the track and they havn't said anything to me. Its down about 1/2 litre in 6 or 7 passes. I only notice the leak after a pass. The car is a 69 back half Chevelle with a front motor plate and stock trans mount. It runs 10.0 at 135mph. I'm hitting nuetral after every pass. Could that have something to do with it? I'm useing Dextron 3 fluid.
jmarksdragster 06-03-2008 02:37 PM
First, go to synthetic, it will reduce temps 10 to 20 degrees. Mobil 1 Dexron V is fine. Second, run the vent into a catch can. If it still leaks, either your case is cracked at the cooler fittings or dipstick tube is leaking, and make sure your servo bolts have not loosened.
jmech 06-04-2008 04:34 AM
Thanks. One thing i can't check is the servo bolts because of the shield. I'll remove the shield and check that first. If it's coming from the vent, what would cause it?
john858 06-04-2008 10:15 AM
jmarks right go to synthetic,helps temp & it made my car more consistant.i don't like the idea of throwing it in neutral after you go through i would leave it in drive.good luck
