-   -   carb loosing fuel in front bowl between rounds (https://www.racingjunk.com/forums/showthread.php?t=20987)
cs 06-03-2008 06:32 AM
i have a dominator ----reworked by chuck n.
the front bowl seems to syfone out between rounds
loads up cylinders hard to start
everything seems ok
any suggestions --------something is wrong
just cost me a motor
OneBadGMC 06-03-2008 07:47 AM
I suggest you send it back to Chuck and have him fix it.
hammertime 06-03-2008 09:11 AM
I agree send it back or call him would be the easiest thing
dcarr511 06-03-2008 09:31 AM
a 2 circuit MB gasket on a 3 circuit carb will cause this exact thing ..... dont ask how I know
altune 06-03-2008 01:42 PM
Most likley the power valve is leaking down. Or if you have one blocked the gasket is leaking, you won't be able to see it as it is under the carb plate.
Al
cs 06-06-2008 05:58 AM
CARB PROBLEM
SET CARB ON STAND FILLED BOWLS
NOTICED FUEL COMING OUT OF SECONDARY NOZZEL ABOVE
BUTTERFLYS
WOULD THAT MEAN WE HAVE A PORUS METERING BLOCK
ANY SUGGESTIONS ?????????????????????????????????????????//
ALSO DOES ANYONE REALLY KNOW WHAT CHUCK N DOES TO THESE CARBS
DOES HE TOUCH THE MAIN BODY ANY ---BESIDES MACHINING TOP OF CARB
THINKING OF PUTTING NEW M BLOCKS ON MAKE BACK TO ORIGINAL
GRASPING FOR ANYTHING
THANKS EVERYONE
Tod74 06-06-2008 07:34 AM
I would try this idea first...all it will cost you is a few minutes and a new gasket...can't hurt anything.
OneBadGMC 06-06-2008 08:20 AM
Re: CARB PROBLEM
BUTTERFLYS
THANKS EVERYONE
It means you need to send the carb back and have the guy fix it.
john858 06-06-2008 09:40 AM
aleast call chuck, he can build a great gas carb.
cs 06-06-2008 11:10 AM
CARB PROBLEM
just a few notes about chuck
we sent this cark to him ran 8.97 to 9.09
got it back $600 plus shipping----we live way north
it ran 9.20 ran good and consistant----wheres my 2 tenths
also had to take jet extensions from front and put in rear
his answer --- o well staff
the time we send back and for him to fix if he can or does i can buy a new dom for $900
also this week 2 other fellows which have bought from him complete carbs
are not working right whats with that---maybe we just get leftovers
will probably send back but will do some more testing
anyone want to buy this carb send me the money its yours
