Starting Issues
Yesterday while trying to start my car I broke another starter (#3 this year), it also pretty well wasted the flexplate (#3 also). My question is this why am I getting a big kickback when cranking ?
Its a bbc with a terminator that has a primer on it. So far I am going to do this what do you think ? Adding a MSD Starter Saver to retard the timing 10 degrees when cranking, I have 0 retard now. This may help ? Going to buy a new starter that I've used in the past that works great. http://www.jegs.com/i/JEGS/555/10001/10002/-1 I have another new flexplate I am going to put on it. A TCI and going to order another spare Jegs Flexplate ($42.00 compaired to $65.00) just in case. http://www.jegs.com/i/JEGS/555/60151/10002/-1 I've been told to elminate the ford selnoid and run the wire back to the starter instead ?? Any truth to this helping ? I checked volts on mine going into it 12.2 coming out 10.6 back to starter. When I am cranking the motor over without ign on I am 12.2 volts everywhere as soon as I crank its 10 volts untill it starts ? Before anyone jumps to grounds and powers this has all been checked and grounds been added to block, chassis all 2 gauge. Powdercoating has been taking off and also paint on block. Battery is a newer Optima Red Top and is good to go My next solution to all this mess is going back to a carb, this is a common issue with injection but hate to give up on it because its a copy machine right now. Any thoughts would be appreciated. |
David
Is it doing this when it is cold or randomly? Are you on alcohol or gas? Did you change anything in your combination this year? One question I have is why do you run the Ford Solenoid, I.E. what are you trying to isolate or protect with it? Curtis |
I have done the ford solenoid and it seems to work good.
The only thing I might try different is the battery. Borrow a battery (fully charged) and give it a try. (Steal it out of the pick up)The battery might be the issue. Good luck |
if you have your timing locked down the timing retard will solve the problem i would think
David
Is it doing this when it is cold or randomly? Are you on alcohol or gas? Did you change anything in your combination this year? One question I have is why do you run the Ford Solenoid, I.E. what are you trying to isolate or protect with it? Curtis I am on alky, I have a primer on it to start with gas though. The ford solenoid comes with the k&r kit and is wired with it so I used it, lots of buddies use it with there carbs and have no issues. I am going to bypass it this week just to maybe elminate something on the list of could be. |
[quote="hammertime"]
What msd box are you running???? Get a Digital box and your problems will be gone :D |
[quote="sg1586"]
What msd box are you running???? Get a Digital box and your problems will be gone :D 7al3 box ... digital should of been on it but I was to stubburn and stuck with the al3 maybe over the winter ?? |
| All times are GMT -8. The time now is 01:15 AM. |
