-   -   LSM cam with alternate firing order ?? (https://www.racingjunk.com/forums/showthread.php?t=20972)
gateman 05-31-2008 04:04 PM
On my new 540, my engine builder talked to LSM about building an extreme pump gas motor - 10.5-1 compression - with 840 degree lift
and 1.8 T & D shaft mounted rockers..LSM wants to use alternate firing
order ( not just the 4 - 7 swap)... What do you guys think?? Motor must make at least 700-725 on the dyno..
edvancedengines 05-31-2008 11:28 PM
I love them.
The C-Swap or 4/7 - 2/3 swap has no negatives. It hellps the engine to idle smoother and it runs smoother and is easier on the crankshaft. The cylinder temps will also be more even and more stable.
Ed
gateman 06-01-2008 03:52 PM
thanks ed... ever heard of A swap?? I vaguely remember something about the A firing order???
