-   -   powerglide brake ? (https://www.racingjunk.com/forums/showthread.php?t=20951)
john858 05-29-2008 04:30 PM
powerglide brake ?
i have a case that is drilled for a double dump pro brake & i was wondering if the case would still work for a single dump full tree brake?should i just use another case?
jmarksdragster 05-29-2008 05:24 PM
I would use another case, it depends on how the VB was made. The passage opened up for the double dump is sometimes used to add pressure to the regulator boost valve on some valve bodies. I did this on mine, but I build my own TB valve bodies and route it differently. Save the other case for a DD VB.
john858 05-30-2008 04:52 PM
thanks thats what i though just wanted to double check my self.thank you very much jmarks, john
