oil filters
Didn't someone say they had cleanable reusable oil filters on here? Do they work as well as the disposable ones? I hope this wasn't a figment of my imagination :lol:
suicidebomb |
Thanks Mark
suicidebomb |
None of these Racer Net prices are including freight charges. I can sell at Jobber. Can not post Jobber.
Chevy style screw on 8440 - 38 gpm = net $200.00 A/C & Typical filters for chev 5-7 gpm flow w/paper type filter. fram hp - 4 rated 9 gal per minute Ford/Mopar style screw on. 8431 - 22 = net $200.00 Ford/Mpar screw on. 4-6 gpm flow w/ paper type filter. Remote Filter Systems 8600 - Ford size filter mounting threads gpm 29 = net $299.95 8900 - GM size filter mounting threads gpm 39 = net $329.95 harley davidson 8110 bf - 18 gpm flow Cost same as Chevy. An example of filtering ability; Pure Power = 12 micron rated nominal. coffee filters = 13 micron flow rating oil filter paper that oil will not flow through = 5 micron GM sized filter mounting thread = 13/16 Special for racing Remote wix racing - 651222R filter mount thread = 1.50 Rated flow = 21 to 24 gpm contains a 18 psi bypass filer diameter over 4'' in dia [ if the surface of paper used in oil filters had holes in it like coffee filters do that oil could flow through, the paper would become saturated with oil and pressure would open the holes up bigger. oil dps not flow through paper. It flows by paper and the paper pleaats and indentations and surface grab the dirt and debris. The pressure exits at the end of filter to the center. |
| All times are GMT -8. The time now is 12:06 PM. |
