-   -   two 1150 dominators (https://www.racingjunk.com/forums/showthread.php?t=20891)
michael1 05-22-2008 01:12 PM
two 1150 dominators
I'm building a 632 bbc with two 1150's, I'm using a set of brodix big dukes (pb1802) and I need to know if this is to much carburetor for this combination. This is a pump gas drag car that weighs about 3400 lbs. Thanks
jmarksdragster 05-22-2008 05:21 PM
If you have them, try them. You may need to go up on jetting a little from factory sizes to make up for loss of booster signal at lower RPM's, smaller MAB's or both. If they are stock 3-circuit 1150's, you may run into the mainwells being restricted too much to get it rich enough at WOT. Spend the money for a dual O2 setup, it will help a bunch to set them up. Spend the time to make sure they open equally from closed to wide open.
michael1 05-22-2008 07:50 PM
the part # is 9377 it says they are used for a tunnel ram set up. I would really like to sell them and use 1050's. I think they would work perfect for all around use.
sc3314 05-31-2008 03:51 AM
Twin Doms
Make sure your runner lenght is correct for your application. That may hurt you more than running the 2 carbs. Much easier to tune a single carb.
Dave
michael1 05-31-2008 10:25 AM
If anybody is interested I will sell both carbs for $800
obsessedtruck 06-01-2008 02:45 PM
Sell them I got a pair of 1050HPs for sale for ya. Used 1 season. 1000$
