Who makes a good egt recorder?What do you use?
My friend wants one for his FED.We are on a tight budget.That is not to say we won't spend the money,we just don't have it :D Just wandered what ya'll used,liked,hated.....Thanks
Computech with dual probes.
2 probes,as in one on each side?Where is the best place to put them?
I have an autometer gauge on two different cars with one probe in # 1 header tude, they work great if you can get the driver to look at the meter going through the traps
GMC,do you know anything about where they say "easily upgradable to 20 channel".Ever done it?Thanks for the link.
Couldn't tell you. I use the pro blower system, so mine is a 20 channel logger.
would the datalogger be legal for bracket racing?
Don't see why it wouldn't, but you should check your local rules.
Usually the only things illegal are automated enhancements. The logger just gives you data. What you do with the data from there is up to you. |
I use a 2 channel meter...simular to the computec one.. I thnk Fluke make one simular to the one 1 have ...The nice thing about it is that it has a min and max button on it...I do the burnout and press the min max button... then make the pass.... on the return road I hit the max button and check both probes.. We run a BBC and I have a probe in both the short and long runner...When we 1st started running I would move the probes to different cyl. on a test day just to see if I had a cylinder that ran leaner or richer than the rest...I think If I was to do it again I would look at the Racedata datta Logger/Dash. Their unit is identical to the Comuptec unit (I think they get them from the same place) so I could see all 8 cylinders and some other settings
| All times are GMT -8. The time now is 11:45 AM. |
