-   -   Need help on BBC alcohol tune.ROOKIES (https://www.racingjunk.com/forums/showthread.php?t=20875)
olds48 05-21-2008 01:12 PM
My buddy has a FED with a port injection Ron's toilet bowl on it.We are having a hard time leaning it out.It is extremely rich.Milks the oil completely on a 2-3 minute warm-up.We run water in the block so as to have a temp reading.Takes about 2-2.5 minutes of idling to hit 140.Goes thru water box at 140,light burnout and still at 140.Kill time staging(we notify the other lane of our problem :D )and creep it up to 160-170.Make a pass(1/8 mile) and it might see 190.
468 BBc
12:1 static comp
B&M 250 Powercharger putting out 12-15 lbs of boost
Edelbrock heads
Cam is Solid roller with specs around 660 lift and 260 [email protected]
Exhaust is zoomies
Toilet is setup with a 80A pump
feed and return lines are both 6 AN and are under 4 ft long each
nozzles are 37
Pill is 80
We tried a 90 pill but line pressure dropped so bad that when we burped the throttle to check the barrel valve it would spit fuel out of the nozzle(around the sponges/air bleeds).It made no boost at any rpm in nuetral with the larger pulley and we had no problem with spitting,but were rich.Wanted to try the smaller pulley(12-15 lb boost) and figured it would help lean out the engine.That pulley would make 3 lbs boost just revving in nuetral.That is when the spitting started.We put the 80 pill back in and still spit too bad.Put big pulley back on with 90 pill and it spit.Only way that the line pressure is high enough to overcome the spitting is with an 80 pill.But then we're rich.Seems we need a nozzle change,but Ron's says to run what we got and just tune around that 80 pill and keep with the 37 nozzles.
BTW.We zoomie for #6 feels cold but plug looks consistent with the rest.Also,entire left side(cyl 1,3,5 &7)feels alot cooler than the other side.????
Thanks for any info,we are both new to alcohol.He can have it,I think I'll stick with gas :D
olds48 05-21-2008 01:33 PM
I messed up.It would do fine,and not spit,with the big pulley and a 90 pill,but was still rich.90 pill and little pulley would spit back.How much should you adjust with the pill before giving up and trying another nozzle?When we went from the 80 to the 90 pill we picked up .03 and 5 mph but were stil way off what we had before.Car has ran a best of 5.17 at 140 mph.Were stuck in the 5.30s now. :(
OneBadGMC 05-21-2008 09:48 PM
Barrel valve is too fat. What's the leak down set at?
olds48 05-22-2008 08:28 AM
I'll have to find out about the leak down.I know that the Rons system has a built in check valve on the return line,nonadjustable at 3 psi,if that is what you mean.You think it could just be in the barrel valveand not the pill and nozzles?
LuckyDawgRacing 05-22-2008 01:03 PM
Oh boy! You're trying to tune and you aren't using a leakdown gauge, Weeeee, are you in for some fun!
olds48 05-22-2008 05:50 PM
This is my buddies car.He has all the fancy toys,we just don't know how to read 'em :D
OneBadGMC 05-23-2008 09:26 AM
Schooled you on carbs... Guess it's time to get schooled in mech injection.
How to leak down a BV using a 2 gauge tester:
1. Block off all injector lines & returns except for hat nozzles
2. Connect dual gauge tester to outlet of compressor
3. Set Air Compressor to read 100psi on 1st gauge
4. Connect tester to inlet of barrel valve
5. Read % on 2nd gauge
A good starting point for a blown motor is going to be 25% on a dual gauge. 75% on a single gauge tester.
Now, go buy this book: http://racecarbook.com/firs.shtml
olds48 05-23-2008 02:25 PM
:shock: :?: Thanks for the info on the leakdown!!
olds48 06-08-2008 10:42 AM
Got the leakdown set,leaner than Ron's reccomends,but seems to be working ok.Thanks for all the info.How do ya'll run your returns?To the tank?Pump inlet-tee?What works best?Also,who makes the best crank trigger?Thanks again!!
OneBadGMC 06-08-2008 12:05 PM
You realize that the leak down is just a base, and that you'll have to change it 2-3 times every day, right?
Start the motor, loosen the screws, fatten it up until it surges, then lean it back out just until the surging stops.
As for plumbing.... See below.
http://i204.photobucket.com/albums/b...c/IMG_0762.jpg
