Cold fusion nitrose jets
I bought a car with a setup allready on, Are these jets the same as NOS? thanks
a flare jet is a flare jet, not much difference exept some are stainless steel, and the other cheaper ones are brass.
er, not exactly. The degree of flare is different and not all jets are interchangeable as a result.
I had bought som stainelss steel nos jets to replace the brass & they look a little different on the base , like they have a litlle bevel where it meets the stem, the brass jet looks like a mushroom, the bas to the stem looks is a 90 degree angle, where the Stainless one tapers a little, if it fits is it ok?
Thanks for the replys |
| All times are GMT -8. The time now is 12:23 PM. |
