ZOOMIES ON A N/A 632
Can you use zoomies on a Methanol N/A 632 BBC.Or what would be the ideal header combination. 2 1/2 to 5" collecters???? 2 1/4 to 4"??????Your opinions would be appreciated. Thanks
No zoomies. leave them to the blown motors.
That engine combo seems to like a 2 3/8" header with a 4 1/2" collector. |
We had a local guy do a A B test @ the track on his dragster. Zoomies and Dynatech 2 3/8 to 4" collector same ET back to back.
So would it be alright if i ran a set of zoomies on it. The motor ia a 632 Chev 15.5C/R Ported BB3 Xtra with spring upgrade and methanol enderle tunnel ram injection. 850 lift cam.which would i benifit from the most or does it matter if i run zoomies
what type of car ?
1968 Holden Monaro Pro modified 2750lbs
Its called pro modified in new zealand and australia so i dont know what it is equivalent to in good ol US of A.
ZOOMS
Run The Z00MIES!They will work JUST FINE!!
Later G 8) |
Yeah! And they look coool 8), and they sound sooo goood 8) :lol:
suicidebomb |
| All times are GMT -8. The time now is 06:39 PM. |
