-   -   Lock out Distributor or Not (https://www.racingjunk.com/forums/showthread.php?t=20814)
JLSTOEC 05-14-2008 06:08 AM
I am running an MSD billet distributor with mechanical advance and am wondering if there are reasons to lock it out. Its a drag car only with a BBC. The car runs fine but I know most people lock the advance on drag only cars. Any thoughts would be helpful.
Thanks
image4you2see 05-14-2008 08:51 AM
Alot depends on compression and what kind of ignition box you are using.
If you have a start retard like most do that lock out timeing then you are fine but if you don't and have a decent amount of compression you could have a hard time getting the car to start with out issues.
Also alot of cars have the timeing locked out because they are using a power adder which is commenly N20 and they do not want the timing to change from were it is.
I hope this helps..
dcarr511 05-14-2008 04:06 PM
Since its a Track only car there is no reason not to lock it out. Its one less thing to go wrong.
Hard starts can easily be overcome by having a seperate ignition switch and turning the engine over and then flipping the ignition on.
altune 05-14-2008 05:33 PM
Locked is best. you dont want something to happen while at wot.
OneBadGMC 05-14-2008 09:19 PM
Hard starts are caused by wimpy ass starters. :lol:
cepx111 05-14-2008 09:23 PM
Drag only cars spend 99% of their time @ WOT so there is no need for a advance curve in the first place. Its the main reason the distributor is locked out, having all of your advance already in aides in throttle response which is especially important in like a footbrake class where you wanting super crisp throttle response off the line.
Hope this helps, Charles
bigs1975 05-16-2008 06:59 PM
My distributor is locked on my car and I have no problem startsint it with no retard.14-1 comp. BBC
olds48 05-16-2008 08:35 PM
I've heard(never seen)of bad things happening with that starting method.Any truth to it?
cepx111 05-16-2008 09:23 PM
Ive dont it that way for years, never had any trouble, spin it over a bit then flip the ignition, works great.
Cp
Tod74 05-16-2008 11:25 PM
I have done it that way but I have also seen it blamed for flexplates getting torn up . If the cap isn't indexed correctly it can jump to the wrong terminal and misfire or something like that...at least that's what I am told.
